camibox (guest)
Guest
Posts: n/a
I have a 99 boxster. The top mechanism is operating but the top will not seat or "park" enough to allow the clamshell to close completely. I had to replace the passenger side push rod ball since it was broken. Any ideas on what is going on? Thanks
This post was auto-generated based upon a question asked on our tech article page here:
Old 04-08-2015, 10:33 PM
Yes, most likely one of the cables has been damaged from the ball cup breakage. That is usually what happens. When opening the top you can usually see a difference in speed between the right and left sides. Another indicator is when closing the top, if one side contacts the windshield frame before the other side it probably has a bad cable. Always replace the cables as a pair.
- Casey
