Need help finding vacuum leak!
I recently had an AOS fail on my 2005 boxster base w/ tiptronic about 800 miles ago and oil went all over the place. Now, I'm getting what sounds like a vacuum leak and I'm having the hardest time trying to locate it. It sounds like a loud, high-pitched "WEEEEEEEEEEEEEEEEEEEE" and is constant from when the engine starts till shut-off.
I suspect that it may have something to do with the transmission, as there is a very short break in the sound when the car shifts up or down and when the throttle is initially applied from idle. Here is a youtube video which seems identical to my sound: https://www.youtube.com/watch?v=L2Bh2Gpj2U8 It's running perfectly smooth otherwise. Smooth idle and acceleration with no CEL. Bently manual was no help. Any help would be greatly appreciated.http://forums.pelicanparts.com/suppo...eys/yltype.gif |
Answered my own question
found the leak. not surprisingly, it was right on top of the transmission.:)
http://forums.pelicanparts.com/suppo...s/a_frusty.gif I used a rubber hose and a funnel to the ear to isolate the leak. http://forums.pelicanparts.com/uploa...1428537345.jpg http://forums.pelicanparts.com/uploa...1428537392.jpg Now I just need to find a part number. |
Best PN would be a section of hose and eliminate the 100 dollar plus subject to break and coolant loss cheap plastic part. Yust my take. I would never replace it again. Did it once.
In researching, some guys over in the rennlist forum posted a metal alternative. Heres a pic and link for anyone interested but I like your solution better. http://forums.pelicanparts.com/uploa...1428582612.jpg Check your heater control valve or watch what can happen - Rennlist Discussion Forums Could I cause any harm to my tiptronic tranny by removing that valve as you suggest? |
| All times are GMT -8. The time now is 08:07 PM. |
