Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Boxster & Cayman Forum
ob1 (guest)
Guest
Posts: n/a
Hello,
Just went to go do the IMS retrofit on my 2000 Boxster with the parts I got from here, Pelican Parts. When I got to the old IMS, I noticed the center shaft is considerably bigger than the one I got from Pelican parts. Does anyone know if the one from LN Engineering has a larger diameter center shaft/center bolt? Or if not, are there any other makers whose centershaft is thicker/larger diameter? I have already ordered and received the parts from pelican parts but if there is already an LN Engineering or upgraded IMS in there, I would just rather leave it in there.
Big Thanks
ps - when I got to the ims, found out it was my rear main that was leaking and not the ims.
This post was auto-generated based upon a question asked on our tech article page here:
Old 04-13-2015, 01:15 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
PCA Certified D.I.
Talking
It sounds like there's an upgrade of some kind in there. If the flange is totally machined steel, I'd guess it's maybe an L & N. If it's a forging with machine work, it will have a Porsche PN stamped/forged on it.
1986, '87,'88 928S4, 2006 Cayman S Cabluey, 2006 Cayman S "Burn Notice"
Old 04-13-2015, 01:27 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Why not post a picture on a forum Jake Raby frequents and ask him? He answered a question similar the other day. (I think he might have a scan for his name mentioned in postings as he seems to pick those up quickly.)
Old 04-13-2015, 03:59 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
JFP in PA's Avatar
Originally Posted by ob1 (guest) View Post
Hello,
Big Thanks
What size is the center bolt nut? Is it 22 MM? Reason I ask is that you may have a late replacement engine in the car, with a non serviceable IMS bearing.
Accrochez-vous bien de vos rÍves..........."
Old 04-13-2015, 05:14 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
