As noted, when servicing the cams on bank one, cylinder #1 is to be at top dead center...compression. When servicing bank 2 cams, should #4 be at top dead center compression? If so, that means rotating the crank 360 degrees if going from servicing bank one to then going to service bank two? Thanks
This post was auto-generated based upon a question asked on our tech article page here:
Old 04-20-2015, 05:24 PM
Yes you will see that the cam lock tool will only fit on the bank which is at TDC compression. So you must rotate the engine 1 turn, and then install the cam lock tool. Make sure that the chain tensioners are installed and tight BEFORE turning the engine.
- Casey
Thanks much. Pelican is a really valuable and generous resource. I really appreciate what you guys do
Old 04-20-2015, 06:23 PM
