James (guest)
Guest
Posts: n/a
Is a special diagnostic tool required to reset oil change service indicator on 2014 Boxster?
This post was auto-generated based upon a question asked on our tech article page here:
Old 05-06-2015, 08:36 AM
Yes you will need a scan tool. This tool will do the reset and allow you to check faults in all control modules including airbag and ABS which are not normally supported by aftermarket scan tools.
http://www.pelicanparts.com/Mini/catalog/ShopCart/TOOL/POR_TOOL_WTD052_pg56.htm
- Casey
