Mike73 (guest)
Guest
Posts: n/a
The parking brake light does not illuminate, should I replace the parking brake switch?
Comments: I have a 97 Boxster. The convertible top has been working perfectly since I purchased the car 3 years ago, however, I went to put the top up yesterday and it did not work nor did I hear the motor operating as I normally would. I have replaced the fuse and tried the button again to no avail. Looking for some trouble shooting tips to follow...
April 27, 2015
Followup from the Pelican Staff: First thing to check is the parking brake switch. Does the light come on when you pull the parking brake lever up?? - Casey at Pelican Parts
This post was auto-generated based upon a question asked on our tech article page here:
Old 05-07-2015, 04:56 PM
Yes, the convertible top relay needs to see that signal from the parking brake switch before it will run the motor. Let us know how it goes! It's on this page:
http://www.pelicanparts.com/catalog/SuperCat/1041/POR_1041_ELSWCH_pg3.htm#item12 ] http://www.pelicanparts.com/catalog/SuperCat/1041/POR_1041_ELSWCH_pg3.htm#item12 [/url] Use the second link not sure why the first duplicate does not work...
- Casey
