-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Question on Boxster Performance Software (http://forums.pelicanparts.com/boxster-cayman-forum/864393-question-boxster-performance-software.html)
Trav (guest) 05-08-2015 10:17 AM
Thank you Casey, one more question, the donor car 2003 is an automatic but my car2002 is a 5 speed. Will the DME or Immobilizer from the 03 have any issues going from an automatic to a 5 speed in my 2002?
This post was auto-generated based upon a question asked on our tech article page here:
Casey at Pelican Parts 05-08-2015 10:17 AM
Hmmm I think that will be an issue. The program in the DME is going to be looking for the Tiptronic control unit communication and will probably set faults and may illuminate the check engine light. I don't know if that coding can be modified after it is set at the factory. One thing you can try is to have a shop or someone with access to a Porsche PIWIS, or Autologic scan tool program the DME with a map out of a 2003 Boxster manual gearbox. That will probably fix the issue. To do this the shop will need to contact Porsche and obtain the Immobilizer code, and iPAS data. Let me know how it goes so we can help others wishing to make that conversion.
- Casey
