2001 Boxster S
Needed: white plastic radio harness clip
I'm adding rear speakers to my 2001 Boxster S.
I was able to pick up a used shelf with factory speakers locally, and bought the rear speaker to radio cable from Becker.
Quoting from the Pelican Parts speaker project:
"Insert the white plastic radio harness clip into the rectangular hole in the roll bar cross-brace, and rotate it 90 degrees to lock it into place (Figure 21). This clip will retain the rear end of the radio harness plug."
Here's the picture from the Pelican project:
Basically, the speaker end of the harness has a connector on it that attaches to this clip. This clip should make detaching the speakers a snap when removing the rear shelf for maintenance.
NOTE: The clip I'm looking for is not the rear shelf clips (999-651-286-02-OEM).
Any help greatly appreciate!
Bill
Old 05-08-2014, 07:41 PM
I'm in the same predicament and found this thread that identifies the mystery white plastic clip:
http://986forum.com/forums/boxster-parts-sale-wanted/52148-wanted-white-plastic-radio-harness-clip.html
Old 05-11-2015, 10:23 AM
