-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Question on Boxster Common Engine Failures (http://forums.pelicanparts.com/boxster-cayman-forum/867237-question-boxster-common-engine-failures.html)
wil (guest) 05-28-2015 10:15 AM
i have a 2002 boxster s with a six speed manual transmission, cant shift to the 3rd speed.i dont know why.
This post was auto-generated based upon a question asked on our tech article page here:
Casey at Pelican Parts 05-28-2015 10:15 AM
I have seen a worn out engine mount make this happen. http://www.pelicanparts.com/techarticles/Boxster_Tech/10-ENGINE-Engine_Mounts/10-ENGINE-Engine_Mounts.htm
Make sure the mount is in good shape. If the mount looks good, adjust the shifter, check the shift bushings. http://www.pelicanparts.com/techarticles/Boxster_Tech/42-TRANS-Short_Shift_Kit/42-TRANS-Short_Shift_Kit.htm
- Casey
