Sean (guest)
Guest
Posts: n/a
I have a 2000 Boxster S. The car starts fine and idles. When the gas pedal is depressed nothing happens. The MAF was unplugged while the car was running and the RPM did increase briefly. The AOS was replaced about a 6 months ago. Just recently had the rear axles, an engine mount and the oil filler tubes replaced. Any thoughts?
This post was auto-generated based upon a question asked on our tech article page here:
Old 05-28-2015, 11:14 AM
Your car needs to be scanned for fault codes. Sounds like a throttle fault.
- Casey
