-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Question on Boxster Engine Sensors (http://forums.pelicanparts.com/boxster-cayman-forum/867241-question-boxster-engine-sensors.html)
Dutchman (guest) 05-28-2015 10:25 AM
Is there a way to add an oil-temp meter to my 986 2,5 1997?
In durametric I can see the oil temperature so the signal is available.
How can I use this and what gauge should I use?
This post was auto-generated based upon a question asked on our tech article page here:
Casey at Pelican Parts 05-28-2015 10:25 AM
http://forums.pelicanparts.com/boxster-cayman-forum/596737-diy-installing-oil-pressure-oil-temp-instruments.html
I think you'll find what you need here.
- Casey
