livvy1960 (guest)
Guest
Posts: n/a
Ref my earlier post - Sorry I should clarify - I have already removed the Drive Shaft and the bearings are notchy / feel indented whilst the assembly is on the bench.
I have new needle roller bearings on order - Please can you advise assembly sequence / process for bearings to Drive Flange Shaft and then assembly to the differential
p.s. the differential is smooth in its operation
Kind Regards
This post was auto-generated based upon a question asked on our tech article page here:
Old 06-01-2015, 11:19 AM
OK, going off of the repair instructions from Porsche. Remove old bearing from differential housing with commercially available two arm pullers and special tool 40-105 (which looks like it sits in the output shaft splines of the differential housing, aka carrier, I believe just gives the two arm puller a place for the tool to push against while pulling the bearing.) To install, heat bearing to approximately 100 degrees C, then put in to position and drive in to place with special tool 40-21. I've included a pic of the tools page so you can get an idea what to get.
- Casey
