emkob (guest)
Guest
Posts: n/a
I have 98 boxter. Recently i replaced little plactic ball sockets that broke. After that I alogned the transmissions and things seem in correct geometry. Problem is every other time I close the top there is a loud thud in sometimes left and sometimes right transmission. This results in nothing broken but transmissions do get out of alignement. If I push on the microswitch on top of the motor durning closing operation the delayed stop works fine. Any clue?
This post was auto-generated based upon a question asked on our tech article page here:
Old 07-01-2015, 08:44 AM
Look for spots where the transmission mechanism could be rubbing on the frame bars. You may need to bend the transmission mounting points so that it does not rub.
- Casey
