Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Boxster & Cayman Forum
tjonesMN
Boxster manual transmission leak
I recently replaced the RMS, intermediate shaft bearing and input shaft seal on my 99 boxster thinking one of them was the cause of a small leak. Also replaced the clutch and pressure plate while I was in there. I know, but it's just the kid's inheritance.
The usual suspects are eliminated and the leak is still occurring.
It sure appears it is manual transmission fluid leaking between where the two main sections of the transmission housing connect together.
I cannot see one other human out there who has had this problem though. Anyone else experience this and fix it??
Old 08-16-2015, 07:49 PM
Did you check the torque on all of those fasteners?
Old 08-19-2015, 04:54 AM
tjonesMN
I did not check the nms with a torque wrench, but I did go around the housing with a socket wrench and make sure nothing would move. All very snug.
Do you happen to know if the two sections have a gasket between them? or loctite?
Old 08-19-2015, 08:46 AM
Not sure but they talk about it here: Transmission repair - Page 2 - Rennlist Discussion Forums
Old 08-19-2015, 11:34 AM
tjonesMN
Thanks for the link. Looks like they used Loctite 574. I appreciate your input.
Old 08-19-2015, 11:44 AM
tjonesMN
https://www.youtube.com/watch?v=MwkwNbEFfE0
Old 08-19-2015, 11:48 AM
Tags
boxster , leak , transmission
