Something's leaking
So while I was changing the oil on my 06 Cayman I noticed the half shaft on drivers rear showed signs of oil/fluid. I assume it would be the half shaft rather than the wheel bearing, but the rubber looks good and the clamp was tight.
Is this a do it yourselfer job without a lift? What are the chances it's the bearing versus the drive shaft? Now my dilemma, I want to change out the suspension so should I bite the bullet on buying it and tackle it all at the same time? What say you? Bob |
| All times are GMT -8. The time now is 10:26 PM. |
