-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Question on Boxster Common Engine Failures (http://forums.pelicanparts.com/boxster-cayman-forum/889700-question-boxster-common-engine-failures.html)
Pat (guest) 11-04-2015 05:29 AM
I have a 2001 Boxster. At about 70 mph it begins to rock from left to right. The rocking begins to get worse until I slow down or speed up. This seems to happen more often on a curve. It feels like I could easily lose control of the car. Mechanic thinks it 'might be' sway bars 3,000 to replace but he's not sure. Any ideas?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Common Boxster Engine Problems and Failures - 986 / 987
Nick at Pelican Parts 11-04-2015 05:29 AM
I would check if you have a bent wheel or bad tire. Then inspect the front end for loose components.
- Nick
