Guest
Posts: n/a
On removing the head light for dip beam replacement the tool is just spinning the bar around with out forcing the unit out to enable removal any help advice greatly received
__________________ This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster Lenses and Blub Replacement / Adding Boxster Clear Corners - 986 / 987 (1997-08) - Pelican Parts Technical Article |
I am not following you. Are you replacing the headlight lever or a bulb? Can you share a photo of what you are having trouble with?
- Nick |
