P1095 after cleaning MAF and TB
I removed the MAF, in tube, TB and plenum to clean them out. I used the correct cleaner and buttoned everything back up. Now the car is idling really bad and throwing P1095.
When I cleaned the TB I did rotate the butterfly with my hand to get the gunk out. There as a good bit. I just read that can damage the sensor inside??? Say it ain't so.
Update: The TB looks fine. I watched it cycle while connected to the car and watched it rotate with the pedal.
Update: Solved. Not look like MAF at all. The lines to the AOS snapped when I replaced it and I had to make hoses. They were not sealing and that is what was causing the MAF code.
I am going to cap off one of the inlets on the intake and AOS.
Old 11-16-2015, 04:08 PM
