Author of "101 Projects"
Vanity Mirror Bulb?
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Victor, the mirror assembly (plastic) gently pops out of the visor material(vinyl) with a plastic wedge- leaving you with 2 wires tethering the two. From this point you can see from the backside all of the plastic tabs holding the two halves of the mirror/light assembly together. From my experience it's not usually the bulbs, but the housing itself that fails. In order to change the housing you must cut the tethering wires and solder the new one together.
Wayne:
If you get a minute could you please verify how gain access to the bulbs in the Vanity Mirror. I was able to lift one side slightly with a small flat screw driver, but the rest wouldn't budge. I would hate to break the assembly...better no lights than a broken mirror on the car. Should I be trying to lift the white plastic lens or the whole assembly out??? Still in the dark....
Vanity Light Issue
I had same issue and finally got around to taking a look at it, girlfriend is vane enough, doesn't need another excuse.. but anyway... the blank insert pops outs...there are some parts of the black frame that act as fingers.. do not try to force the thin edge near the cover hinge...it will break ....I found prying from the outside edge of the black frame towards the center, parallel to the place of the mirror. This means the rounded edges get pryed left to right (for the left side), right to left (for the right side) and back to front (for front edge) assuming the mirror is facing up towards the ski (and the cover open obviously).
If you move the black plastic and have a flashlight handle, you should be able to see the tabs. One is in the center of the front edge and the rounded sides have one also. and then face outwards. There are also 4 inward clips on the front and back edges which tuck behind the mirror. Use a thin flexible plastic spaced to push the plastic frame away from the mirror on long edge next to the hinge first and then work your way around in either direction. It is only a brass plate with a hole in it which makes contact to the edge of the bulb. As previous posters said, probably not the bulb, probably just oxidation on the contact. rotate the bulb a bit and it may come right on... As soon as I pryed up the black insert..my lights came on. I slight the mirror slight parallel to the long edge and it seems to address the intermittent access. I did not remove the mirror. I used a flash light to try to see under the mirror and I think I saw some clips there also, but since the lights were now working..I did not try to remove.. Last edited by pelsteve1; 11-24-2015 at 09:05 AM.. |
