Clint (guest)
Guest
Posts: n/a
Hello,
If the double row bearing is widerdeeper than the single row. Does that mean the recess in the ims shaft is deeper for the double vs the single row and therefore the two ims
shafts are not interchangeable?
Clint
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Intermediate Shaft Bearing Replacement and Upgrade (IMS) - 986 Boxster (1997-04) - 987 Boxster (2005-06)
Old 02-15-2016, 05:20 AM
Nick at Pelican Parts's Avatar
yes, I would assume so.
- Nick
The IMSB is not interchangeable between different design shafts.
The IMS is interchangable between engines as long as the crankshaft drive gear matches the IMS drive gear. The IMS drive gear was improved during 2001,along with the weaker single row IMSB, so if you have a 2001 engine it could be either design. The LN IMSB PRO is a dual row bearing that can be installed in a single row IMS, The LN Solution is a better solution as it eliminates the roller bearing altogether.
Old 02-16-2016, 11:02 AM
I thought they were ball bearings (factory), not roller bearings...
Old 02-16-2016, 11:09 AM
Yes OE IMSB's are ball bearings, I was trying to differentiate from the Solution which is a solid "bushing" type bearing.
Old 02-16-2016, 11:48 AM
Isn't one (some) of the aftermarket bearings roller bearings?
and there is the 'bushing' bearing, too.
Old 02-16-2016, 03:15 PM
