gear cable brass fitting broken? pics!
I noticed I had problems shifting 2nd 4th and reverse. I checked the gear cables and notice the brass part is slit out of where it's suppose to be
1st pic is how I found it, brass piece out of the fitting
2nd pic is how it's suppose to be. I can shift all gears but only a few times and it falls back out. What's wrong and how do I fix it? I know it's because the brass part keeps falling out. What do I do? Thanks!
2003 Boxster
Old 11-28-2014, 06:31 PM
JFP in PA's Avatar
2003 Boxster
Cable needs to be replaced.
Accrochez-vous bien de vos r๊ves..........."
Old 11-29-2014, 06:28 AM
Tsunamiboy's Avatar
I lost 1st, 2nd, and reverser on thanks giving day. I limped along in third and fourth gear to a Porsche shop. One of the two shift cables broke so both are being replaced. I have 105,000 miles on my 1997 Boxster.
I just replaced the motor mount which was completely destroyed. the rubber bushing was totally separated from the support frame. It must have been that way for quite a long time and I believe the bad motor mount had something to do with the deterioration of the shifting cables. I was experiencing vibration at certain RPM's for quire a while. After replacing the motor mount the shifting was much smoother as well as starting from a stop became smoother as well.
Cause and effect (bad motor mount, broken shift cable) ?
Tsunamiboy
1979 911 SC (3.2L)
1997 Boxster 986
Old 11-30-2014, 11:21 AM
one of gods prototypes
bell's Avatar
I'm seeing more and more failing boxster shifter cables at the shop.......i expect them to be the next common failure, i have seen no relation to engine mounts or short shifters yet.....but all failing in similar spots
Brought to you by Carl's Jr.
Old 11-30-2014, 11:39 AM
Author of "101 Projects"
Wayne 962's Avatar
I concur, the shifter cables on these cars have a limited life - particularly the plastic bushings on the end (which you cannot replace separately - we might be looking into having them manufactured). I don't have a good article on the shift cables, but the short shift kit article in our tech articles section shows the removal of the cables at the shifter end, and the engine drop article shows the removal of the cables at the transmission end, so that covers the info...
Porsche Boxster 986 (1997-2004) / 987 (2005-2008) Technical Articles | Pelican Parts
-Wayne
Old 12-10-2014, 09:19 PM
It'll be legen-waitforit
stealthn's Avatar
Old thread but I didn't realize this was a common problem? Numeric Racing makes replacement cables but did Porsche address this with replacement cables if it's that common?
Bob James
06 Cayman S - Money Penny
18 Macan GTS
Old 02-22-2016, 05:43 PM
