-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Ignition switch problem (http://forums.pelicanparts.com/boxster-cayman-forum/924737-ignition-switch-problem.html)
Stike 08-08-2016 12:48 PM
Has anyone had a problem with the ignition switch springing back to the run position after starting? Mine just stays in the start position until I turn it back myself.
JFP in PA 08-08-2016 01:18 PM
Ignition switch electrical section is a common failure point, do a search, an easy DIY fix.
