Author of "101 Projects"
Wayne 962's Avatar
Here's another photo of the drain (yellow) and fill (purple) plugs on the six-speed transmissions.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Differential / Manual Boxster Transmission Fluid Change - 986 / 987
Old 09-05-2011, 11:45 AM
bspank's Avatar
6 Speed Fill & Drain Plugs for 2000 Boxster
Does Pelican Parts sell those fill and drain plugs? Perhaps with a magnet? Previous owner/mechanic buggered mine up; see below. I got them out but don't want to reuse. Knowing that the 5 and 6 speed have different plugs, from Project 38, I want to make sure I get the right ones. I'm having a heck of time trying to find these. When I do find the plug that isn't for the Tiptronic they don't differentiate the 5 or 6 speed.
Bspank
Old 09-05-2016, 09:02 AM
Cayman Lover
Darn, hate it when someone uses sae instead of metric size tools. Should be 17mm wrench and yup Pelican lists the plug, at least for a 986
Clinically proven to be smarter than you're!
Old 09-05-2016, 12:54 PM
HERE is the fill plug.
HERE is the magnetic drain plug.
HERE are the seal washers
My sincere apologies for not listing in the catalog!
Old 09-06-2016, 11:19 AM
I believe they are 10mm allen socket to remove. The older 915 gearboxes had the 17mm
Old 09-06-2016, 02:42 PM
Cayman Lover
By the way your first link goes to a 911 Air box plug?
Old 09-07-2016, 04:36 AM
Yes I am not too sure why the description is listed like that, but the plug is the same according to the Porsche Parts Diagrams.
Old 09-07-2016, 09:13 AM
