Filter Question
I was changing the filter on my '99 Boxster today and noticed a spring loaded valve in one end of the old filter. The filter fell out of the base when I removed the canister, so I can not tell which end it belongs in.
I assume that it is a pressure relief valve for the filter to circulate oil if the filter is clogged. I that correct? It appears that it needs to go in the bottom of the cannister. Is this correct? David Nolen '99 Boxter '70 911 |
Yes and yes.
Thanks!
David Nolen |
| All times are GMT -8. The time now is 05:09 AM. |
