I am ready to order all the parts but am unclear on one thing. After I create the wiring harness as described and plug the 4 wires into the harness behind my instrument cluster and attach the ground, I am unclear where the plug end of my "new" harness goes as well as the two harnesses that were already coming out of the 4 stalk switch.
Thanks in advance for any help you can lend so I can pull the trigger on this. __________________ This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster On Board Computer (OBC) Upgrade and Turn Signal Switch Replacement - 986 / 987 (1997-08) - Pelican Parts Technical Article |
The new harness plugs into the stalk assembly and the vehicle harness (as you mentioned). Is this what info you needed?
- Nick |
Nick,
I appreciate your reply, but it is similar to others I have received, just not specific enough. I think we are good on where the ground and the 4 wires with the connector tips go, could you please, specifically, tell me where the connector on the end of the new harness plugs in? (I figured it went to the stalk assembly.....but need more info) Does it plug into one of the 2 harnesses that come off the 4 stalk switch? If so, which one? Additionally, If that the case, where does the other harness from the 4 stalk go? Sorry to go into so much detail, I just need to make sure I know what I'm doing before I move forward..... Thanks, Brian |
| All times are GMT -8. The time now is 06:45 PM. |
