1998 Boxster tires
just bought this car. can anyone tell me if i can put wider tires on it without modification. it currently has 255/40/r17 on the back.
Thanks!
Old 11-21-2016, 07:14 AM
depends on the wheel width. What width is the wheel 8,9,10??? To go wider, you need the right wheel with the correct offset. Too wide a wheel with the wrong offset and you rub either on the inside shock tower or outside on the fender. You want all of the wheel dimensions and then contact Tire Rack and ask someone there what will fit.
Tony G
2000 Boxster S
Old 11-21-2016, 09:20 AM
ok on the front i have 7.5 and back i have 8.5. according to tire rack they dont have any other listings other than the 255/40/r17 for the back.
Old 11-21-2016, 10:13 AM
M. Murphy's Avatar
I have 265 35/18 on the back of mine.
Old 11-21-2016, 11:08 AM
Try this and see. Online Wheel and Tyre Fitment Calculator. Offset, Tyre Stretch and Speedo Error | Will They Fit
Depends on the wheels that you are using.
Maybe a better question would be to ask what you are trying to achieve with the wider tires? How much you are willing to trade wear for what you hope to achieve? (The rears already wear faster than you would want!)
How is the alignment set up? Do you have access to someone who can set the car up to achieve what you want? The guy doing it can make a world of difference. Look for someone who sets up the suspensions of water cooled Porsches for racing.
Old 11-21-2016, 05:29 PM
