CD Changer stuck cartridge
Hi. I've got a problem with my CD Changer. It ate the cartridge!!! I have a 1997 Boxster with the CR-210 deck and CRC-3 Changer.
I loaded a CD into the cartridge and popped it in. I could hear the motor run inside for a second or two. I went into the car and selected CD mode and it said it was cycling through the CD's, Disk 1, Disk 2....it then said there was no disk and went back to radio mode. I figured I must have loaded the CD backwards. When I pressed the eject button on the Changer, I could hear the changer motor run for a quarter second or so and stop. Now nothing happens.
I then removed the radio fuse and waited 5 or 6 minutes, reset the fuse and powered it back on. Same thing, you can hear the motor run for a brief moment and then nothing.
So now my Steely Dan CD is stuck!!!
Any ideas on getting it out?
Thanks!!
Old 12-11-2016, 09:25 AM
