Mystery connector
Last night during storage prep I removed the battery from my 98 Boxster base and noticed a two wire connector that was disconnected. The joining part has brown (presumed ground) and yellow/black wires. The connector is secured to the firewall and the wires are small gage. Any ideas what this might be for?
Thanks. |
Are you the original owner? A connection for a GPS tracker or security system?
I think I've figured it out, aftermarket wiring for a radar detector. PO.
Thanks |
Mystery connector
Solved.
Identified connectors and wiring as the heated washer nozzles. |
