Daniel 987 RS60 (guest)
Guest
Posts: n/a
I have a 2008 Boxster RS 60 Spyder with 21k miles. Is there anything I can do to avoid the IMS failure? My understanding after reading your articles is that it's something easy to fix in older models and it doesn't affect newer ones, but in my car's case nothing could be done.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Common Boxster Engine Problems and Failures - 986 / 987
Old 01-10-2017, 08:09 AM
Nick at Pelican Parts's Avatar
Keep up to date on oil changes and drive the vehicle. I do recall LN having a kit to make the later engine bearings serviceable, but you have to disassemble engine to install the adapter..
- Nick
2008 ims
Weren't there some folks who were removing a seal to allow oil to better lube the bearing?
Old 01-10-2017, 10:05 AM
