boxster oil change
I have changed my oil and filter, how can I turn the change oil message off?
On my Cayman I use Durametric software and cable . They say that an Icarsoft scanner will do, it but I have not tried it. A dealer or import garage will do it but probably charge you.
Administrator
Durametric is not inexpensive, but worth the investment if you plan to DIY more often. I posted scanners below for you to view:
Porsche Boxster (1997-2004) - Tools - Page 8 |
Durametric works, I used it with my laptop, pretty easy to navigate. Unfortunately I misplaced mine during a recent move. It is packed somewhere !&Xx .
My warning reminder drove me nuts and I bought themicarsoft on amazon prime,I can confirm the Icarsoft works just fine! If all you are doing is reset the service reminder it is perfect, saves money and does not require any computer. Pretty compact, I keep mine now in one of the front trunk compartments so it is always in the car. I used it recently to erase the airbag light after I had to jump the car. Great deal! iCarsoft POR-II Porsche OBD-II Scanner Tool i960-II NEW version https://www.amazon.com/dp/B011DKBXBK/ref=cm_sw_r_cp_tai_1c4IybYS016FE
Dietmar 1987 911 Carrera 2008 RS 60 Spyder |
Accrochez-vous bien de vos rêves..........." |
I can only speak for my experience. The menus are not intuitive and it takes a little to navigate them, but mine has done the job. No problem with service reset and erasing error codes. I cannot speak for the 15% that don't work, don't know if their units are defective or if the operators couldn't get it to work.
If you have Amazon prime just return it free of charge, no shipping fee.
