topher (guest)
Guest
Posts: n/a
I have a 2002 2.7 blown engine. Any issues putting in a 2000-2001 2.7 engine in? dme fuel return...?
This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster Engine Conversion Project - 986 / 987 (1997-08) - Pelican Parts Technical Article
Old 02-17-2017, 07:36 AM
You may have to swap some stuff from your old engine, but it will work. Once you get the two side by side the parts differences will be obvious and you can swap over what looks different.
- Casey
No issues swapping the long blocks as all 3 years are identical. As for the bolt on accesories use yours from 2002 if in good working order. Especially fuel parts as 2002 has best fuel return & fuel injectors.
Old 02-18-2017, 12:03 PM
