Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Boxster & Cayman Forum
flynsfun (guest)
Guest
Posts: n/a
flynsfun: I have a 2006 Boxster, tiptronic. Right rear brake light stopped working. All running lights, turn signals, left brake light OK. Right bulb OK. Fuse OK. Took out right light assembly and hot wired it and all lights worked OK including right brake light. Is it possible that corroded contacts in brake switch causing only one side to malfunction?
This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster Brake Pedal Switch Replacement / Clutch Pedal Switch Replacement - 986 / 987 (1997-08) - Pelican Parts Technical Article
Old 03-20-2017, 01:55 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
I doubt it, see if you can have an assistant press the pedal while you measure voltage at the bulb socket...
- Casey
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
