-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Idle problems & maf sensor question (http://forums.pelicanparts.com/boxster-cayman-forum/950649-idle-problems-maf-sensor-question.html)
godogo 03-24-2017 12:33 AM
Hello. Sorry for the bad english. I have problems with the engine running at idle. I cleaned the throttle and the MAF sensor. This partially helped, but then the problem manifested itself again.
When I disconnect the Maf sensor and start the car, it turns off. This is normal?
Today, after the problems started, I disconnected the Maf sensor. I tried to start a car. Then i reconnected the Maf sensor. The problem is gone. What does this mean?
Thank you very much for your help.
Boxster 986
Dmitry at Pelican Parts 03-24-2017 12:09 PM
Hello and welcome to the forum! I've included a link to one of our site's DIY tech articles on the MAF and troubleshooting it. If you have anymore questions or need specifics, please post a Comment just below the article and we'll do our best to give you details. Best of luck!
Porsche Boxster Mass Air Flow Sensor (MAF) Replacement and Troubleshooting - 986 / 987 (1997-08) - Pelican Parts Technical Article
-Dmitry
