-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Reconnecting the clamshell (http://forums.pelicanparts.com/boxster-cayman-forum/958318-reconnecting-clamshell.html)
Brian Minson 05-29-2017 02:15 PM
Is there a trick to reconnecting the clamshell? I removed the pins as everyone says todo to get better access to the engine. However, I can't seem to get these two to come together. Hitting the button inside doesn't seem to move the rod to give the extra 1/2 inch needed.
http://forums.pelicanparts.com/uploa...1496092463.JPG
M. Murphy 05-31-2017 04:08 PM
Brian, did you ever get this figured out? I can't get the clips off mine.
KermitInCleve 06-03-2017 11:52 AM
To get the clips off, I just used needle nose pliers and pulled them off.
I also had trouble getting it reconnected. It seems like something shifted. To reconnect, I pulsed the switch watching it until I could get it lined up again. The top was pretty much all the way up before I could connect it. I think my top needs adjusting buts it's now down and I'll worry about it when I take it in for service.
Kermit
2000 Boxster S
148,000 miles
