Phantomboy
AOS lower hose clamp tool
Looking through the 101 projects for your Boxster, I found the section on replacing the AOS filter. The advice in section 3 is to replace the flexible hose that connects to the right side cylinder head. He says there is a special set of pliers to remove the spring clamps. Where can I find these special pliers? Thanks
Old 06-27-2017, 03:44 PM
M. Murphy's Avatar
I'd like to find the plastic retainer that holds the clamp open until you're ready to release it. Autozone was not aware of them but has a cable clamp pliers set for $36.
Old 06-27-2017, 03:49 PM
M. Murphy's Avatar
Here's an image.
Old 06-27-2017, 03:51 PM
Phantomboy
Thanks, I'll check it out!
Old 06-28-2017, 09:40 AM
