oil in coolant.... Help!!
ok, here we go... 02 boxster with a 00 S motor in her after an ims bearing failure a couple years ago... I came outside to notice a puddle of oil under the car, i popped the trunk and checked the oil to find it low and then removed the coolant reservoir cap to find the mocha colored mix when oil mixes with coolant.. i know the worst case scenario in which case, anyone wanna buy a car? lol .. but i've been reading in my research that the oil cooler failing could also allow oil to get into the coolant.. i have no signs of coolant in the oil and the car doesn't smoke... anyone have any experience with this problem? also, can the aos squeal on start up? ...Thanks for any input!!!
Old 07-18-2017, 07:22 PM
txhokie4life's Avatar
it's possible a cracked cylinder or head could have a one way preference that the path is pressurized and oil enters the coolant chambers, but not the other way.
I can't remember if the AOS is cooled with coolant or not.
Worst case? Where are you located?
Mike
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo
2001 996 GT2
1999 Spec Boxster, 1996 993 Cabriolet
1992 964 Cabirolet, 1975 911 RSR Replica Race Car
Old 07-19-2017, 08:33 AM
JFP in PA's Avatar
Mike
An 02 Boxster would have a dry AOS.
Accrochez-vous bien de vos rêves..........."
Old 07-19-2017, 08:49 AM
I'm in Melissa Texas, near Dallas
Old 07-19-2017, 09:07 AM
You might check your oil cooler. Sorry to hear.
Regards
Old 07-19-2017, 10:29 AM
You need to get that completely out of the system as soon as possible. If you leave it in there you will need to replace every hose and have the rads dipped to be cleaned. It simply will not get clean enough. Ask me how I know! There are about $1500 bucks worth of hoses to replace, never mind the engine repair or replacement. You have an intermix situation. Either a cracked head or some other failure allowing oil and coolant to mix.
Tony G
2000 Boxster S
Old 07-21-2017, 08:36 AM
JFP in PA's Avatar
And be prepared for literally hours of labor. We have cleaned out several of these and it takes time, fortitude, and good equipment. Not fun........
Old 07-21-2017, 09:08 AM
Thanks for the 411!
Old 07-24-2017, 02:29 PM
Mike
