Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Boxster & Cayman Forum
herbhenry2222 (guest)
Guest
Posts: n/a
I have what sounds like a belt squeal. When the squeal is loud the oil pressure light comes on, punching the accelerator turns it off. Changing the belt didn't help. WD-40 on the bearings didn't indicate anything. Curiously, when I switch off the motor and the belt stops turning, the squeal continues for almost a second. Please help.
This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster Idler Belt Pulley Replacement - 986 / 987 (1997-08) - Pelican Parts Technical Article
Old 06-29-2017, 09:40 AM
probably not belt related if the oil light is coming on. Check oil level, condition and pressure.
- Nick
JFP in PA's Avatar
I would also check for a loose spark plug.
Accrochez-vous bien de vos rÍves..........."
Old 06-29-2017, 10:41 AM
Your idler pulley and tensioner pulley bearings are sealed. A spray lubricant can't penetrate the seals. Spraying WD40 would only help if the squeal is coming from the pulley shaft (retaining bolt).
Pull the belt. Wiggle all of the pulleys (water pump, AC and drive pulley too) if any of them have play replace it. That is probably the problem. Even if it doesn't stop the squeal, the pulley (actually it's bearing) is bad anyway. You can either pay $70 +/- for a pulley or $5 +/- for a bearing and have it replaced at a machine shop for $10/$15. You might as well do both idlers and the tensioner at the same time.
Technical Tip: I use a dental tool and pull the seals. Then I repack the bearings with Mobil 1 Synthetic Grease and reuse the seals. You can also apply a thin coating of the grease to the spacers and bolt (only) where the pulley rides.
Old 11-02-2017, 05:51 AM
M. Murphy's Avatar
Interesting, do you source the replacement bearings from Detroit Ball Bearing? Could they be pressed in/out with a small arbor press?
Old 11-03-2017, 09:33 AM
Sourcing the bearing can be a little tricky. Instead of trying to cross reference them on the internet, find a local supplier and (if possible) take them a pulley. You will have to remove the belt and at least one pulley to get the number off of an actual bearing. The bearing numbers are concealed by the washers/spacers. You can't see the numbers, while they are on the car. All three of my pulleys used the same bearing. That isn't always the case. I have a 2001 Boxster base that I've had for 11 years.
I tried to buy bearings using a number referenced in a YouTube video that I thought would work. That was a mistake.
In the short term, I used a dental pick and removed the seals for both idlers and the tensioner pulley. I used a tooth pick to dig out the factory grease (there wasn't much) and then used a wooden coffee stirrer to repack them with Mobil One Synthetic Grease.
They weren't loose so I reinstalled them, with the original seals.
I found a local machine shop that pressed in my new motor mount for $20 so when I find the correct bearings I know they will replace the bearings for a few bucks.
Old 11-14-2017, 12:59 PM
