1999 boxster headlight problem
Headlight question. I have a 1999 boxster and I am having some issues with my passenger side front headlight. The low beam bulb went out and I replaced it and everything was working fine. Then a week later the turn signal bulb went out and I replaced it.
Now none of the lights on the passenger side are working or the turn signal. Any ideas as to what the problem might be or how I can fix the problem? Thanks Steve
Old 07-08-2017, 03:42 AM
JFP in PA's Avatar
You probably have not properly reseated the head light assembly when you reinstalled it. This is a common problem, try reseating the unit.
Accrochez-vous bien de vos rêves..........."
Old 07-08-2017, 07:50 AM
