Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Boxster & Cayman Forum
Question on A/C Overhaul
Historically, I have had a slow freon leak in my system, which I believe was traced to a leak high pressure port valve in part. So earlier this summer, I decided to recharge. Unfortunately, during the process, I had a fairly violent high pressure side hose breakage during a/c pressure gauge hookup and lost a major portion of the freon. I never lost all the freon and the system still had charge in it, so I did not reclaim the balance and vacuum. I simply recharged the system but it is not performing properly.
If I recall correctly, the high pressure side is not quite high enough and the low pressure side is on the higher side of the range, so I suspect the compressor is going.
I am inclined just to overhaul the system and my questions are as follows.
With such a violent high pressure side loss, how much oil is lost in the process and how to determine it?
If I were to going to swap out the compressor and put new port valve on, likely on both side, as long as I have the system open, what else should I go ahead and change before sealing it up again and how much oil to add?
Any comments, pointers etc appreciated..
Old 07-08-2017, 03:07 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
JFP in PA's Avatar
When you get into this type of failure, it is often very difficult to determine how much oil was lost. Porsche service manuals contain a chart listing how much oil should be in each component, but is predicated on a proper recovery decompression of the system, not a catastrophic blow out which can vent a lot more oil.
You may be reduced to having to flush the system with a special solvent to remove all remaining oil, and then start over from scratch with a full oil charge.
Good luck with this one.....
Accrochez-vous bien de vos rÍves..........."
Old 07-08-2017, 07:48 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
just to close this out, I have another post on the same subject..see those comments
Old 09-05-2017, 12:08 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
