Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Boxster & Cayman Forum
camshaft position sensors and camshaft solenoid
My 1999 Boxster with 185K miles keeps giving me code P0341 as well as codes for misfiring of cylinders 1 to 3. I have replaced the camshaft position sensors and the coil pacs and the P0341 code comes back after driving for only 5 minutes. Should I replace the camshaft solenoid?
Old 08-30-2017, 02:45 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
JFP in PA's Avatar
P0341 is the code for an "implausible signal" on the bank one cam position sensor; more often than not, this is a harness issue.
Accrochez-vous bien de vos rÍves..........."
Old 08-30-2017, 03:01 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Camshaft position sensor
Do you mean the wiring between the sensor and the DME or something else?
Old 08-31-2017, 12:25 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
JFP in PA's Avatar
The DME is seeing an irregular signal, could be a short, broken wire, or loose connector anywhere in the harness for this sensor. Without the legendary pin out box, this is going to take a lot of circuit testing to find it.
Old 08-31-2017, 01:09 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
