Replacing tires ...Boxster 09 Base
For 18" wheels, what size tires will fit the rear...(bigger than 265)
Foolproof underestimates the dedication of fools
Old 10-08-2017, 04:03 AM
Administrator
Dmitry at Pelican Parts's Avatar
Hello - are you inquiring about what the biggest tire that will fit without any modifications such as spacer or are you okay with using spacers if needed? I'm also attaching a really helpful guide on wheel fitment and spacing/offset below.
Wheel Fitment & Spacing Guide
Old 10-09-2017, 01:30 PM
I just went through this with changing the wheels on my BMW 530xiT...(that car has another problem because it's a 4WD...so I am aware of the offset etc....)
I was just thinking to make the rear look wider with bigger tires, I'd avoid spacers if possible. I thought to use bigger tires on the o/e 18" wheels.
How "big" can I go?
Old 10-09-2017, 02:19 PM
Assuming your rear wheels are stock, they are 9" wide. 275 is the widest tire which will fit properly.
Old 10-14-2017, 07:03 AM
