Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Boxster & Cayman Forum
Nytram (guest)
Guest
Posts: n/a
Boxster 3.2 2000
In a short space of time it is almost impossible to put into reverse. and now 1 and 2 and getting harder to engage. The pedal is getting sticky.
My mechanic is going to have a look and thinks its a clutch fluid leak. the car has 65k on the clock. Whilst it is in the shop, is it worth getting the master and slave replaced irrespective of being faulty...?
This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster Clutch Hydraulics Overhaul (Master Cylinder & Slave Cylinder Replacement) - 986 / 987 (1997-08) - Pelican Parts Technical Article
Old 10-21-2017, 09:08 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
if the hydraulic system is at fault, I would replace the master and slave as a set.
- Nick
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Jeff Alton's Avatar
If a hydraulic issue it would generally be the slave bypassing. No need to replace a good master if it is still serviceable. Your shop should determine where the issue lies before they replace any parts.
It could also be a failing pressure plate which is not uncommon.
Cheers
jeff@turn3autosport.com
997 S 4.0, Cayman S 3.8, Boxster 2.7, Boxster S race car, 996, 955 Cayenne TT, 958 Cayenne TT
Old 10-22-2017, 07:29 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
