I can't tell if this is a single row or double row. I think its double row.
Old 04-23-2018, 02:21 PM
JFP in PA's Avatar
Check the size of the nut on the IMS center bolt to see if it is 22MM
Accrochez-vous bien de vos rÍves..........."
Old 04-23-2018, 02:23 PM
the nut size is 13mm. 22mm would be huge.
Old 04-23-2018, 02:54 PM
This guy has a double row and has a 13mm nut.
https://www.youtube.com/watch?v=lbM3c2V4scw
About 2mins in he says 13mm for the nut.
Old 04-23-2018, 02:57 PM
JFP in PA's Avatar
If was 22MM, it would be the non serviceable third design bearing, which is why I asked.
Old 04-23-2018, 03:11 PM
I forgot to mention it's a 2001.
Old 04-23-2018, 04:12 PM
We went thru this discussion when I replaced the engine on my 01. The one coming out had the smaller nut on the IMS bearing & was leaking oil quite badly. The engine I replaced it with had the larger nut and was a factory remanufactured/used engine.
JFP, I don't quite understand the concept of a non serviceable IMS bearing. Is the factory replacement a better bearing setup? Non serviceable means it can't be changed? For all you do, Thank You!
Brian Lamberts
Tucson AZ
Old 04-24-2018, 05:55 AM
JFP in PA's Avatar
Porsche moved away from the dual row to the single row, probably because of costs, and the single row turned out to be a bad idea with much higher failure rates. In 2005, they went to the third design, common called the non serviceable bearing because its physical size prevents it from fitting through the opening the rear of the engine cases, and there by requiring a total engine teardown to change it. Unfortunately, this last design still failed, but not in as large numbers as the single row. This left owner's with 2005-2008 cars with few options to prevent failure.
Old 04-24-2018, 07:49 AM
Occasional User
Looks like a dual row - see differences at 23:00 of video
https://www.bing.com/videos/search?q=pca+ims+video&view=detail&mid=48AC121505E06067D2AC48AC121505E06067D2AC&FORM=VIRE
Vince
1989 911 Silver Coupe - sold
2009 Cayman S White, Full Cocoa Leather - sold
1972 911E Silver, Pepita & Black - sold
Old 04-24-2018, 10:23 AM
Thanks for that link. I had previously watched most of that, but didn't catch that part.
Definitely the bearing I have is a dual row. The single row cover looks like it would be much more difficult to hold the center stud and then remove the nut with a wrench compared to the dual.
Now the big question, to leave the dual row in or not? Supposedly the failure rate of the dual row is .7%. I feel that for me to remove the bearing and replace it I would probably have a much higher probability to jack something up than .7%.
Ironically I was pretty sure before that I was going to have the single row because I am never that lucky.
FWIW my car is a 2001 with an 04/01 mfg date. I assume original engine.
I think I am the 3rd owner. I bought it a little over 6 years ago.
It has almost 80k on the clock.
Old 04-24-2018, 05:27 PM
All righty, I finally got it all back together today.
Overall the clutch job isn't that bad.
The absolute worst part of the job was drilling out the sheared off exhaust bolts. If I had to guess, to drill out the 6 bolts I spent probably about 4-5 hours. On the last bolt I used a grocery store HSS drill bit set and was able to get through one in 15 minutes.
The second worst part was reattaching the transmission. I wasted a few hours guessing how to do it until got some wheel hangar hardware that helped to line things up.
Maybe the third worst part was pushing the intake duct back onto the throttle body. I had to get out my heat gun to heat it up to get it back on.
Now to get the emissions test taken care of and get my tags renewed.
Old 06-17-2018, 02:45 PM
