Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Boxster & Cayman Forum
Cluster shutoff
Anyone have this issue? I will be driving and cluster/instrument gauge shuts off for one second and comes back on.
Thanks!
1997 Boxster
Old 10-24-2017, 05:41 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Administrator
Dmitry at Pelican Parts's Avatar
Hello and welcome to the forum! Have you checked the electrical/fuses?
Old 10-25-2017, 11:27 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
I don't think that would account for a momentary shut off of the gauges. The fuse is B1, btw. More likely, tho, is that the connection or points in the ignition switch are bad or corroded. I think that movement of the key ring might be disturbing the connection in the switch. Do you have lots of keys on your ring?
Brian Lamberts
Tucson AZ
Old 10-28-2017, 07:19 AM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
No keys on the ring. Past owner changed battery and didn't use OEM. Key remotes (i have 2) do not lock or unlock the car.
The cluster actually does not count mileage it stays at the same mileage, it just resets completely including the time while i drive and it happens every 2 miles. Any ideas?
Old 10-30-2017, 10:03 AM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
My instument cluster started flashing & the speedometer, tach, gas & temp gauge would not work. The headlights & tail lights would blink off & on when turned on. The interior lights would flash if turned on. I took to dealer in Florida, Auto Nation, & they never heard of problem. I called Chrysler Corp. & they never heard of problem.. The dealership was terrible, but Chrysler Corp helped & they finally replaced the TIPM, Total integrated Power Module. The car worked fine but only drove short distances. When I started driving home to Michigan, the cluster started doing the same thing after driving 100 miles. The second day started out fine, but after 100 miles, the instument cluster went out again. I was worried because the headlights flash also. Will take to local dealership on Monday, but I called them from Florida & they never heard of problem either. When cluster goes out, the headlights & taillights also flash when turned on, but the radio, air conditioning/heat work fine.
Old 11-08-2017, 10:04 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
Originally Posted by warren90anthony View Post
I called Chrysler Corp. & they never heard of problem...
Why would you call Chrysler about a problem with your Porsche?
Brian Lamberts
Tucson AZ
Old 11-10-2017, 06:24 AM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Have you tried cleaning the battery posts and making sure the connectors are nice an tight?
Brian Lamberts
Tucson AZ
Old 11-10-2017, 06:25 AM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
So I have narrowed it down that it shuts off at .5 miles. It does not record the mileage either. The lights stay on, there is no other problem than the whole cluster. I think I will just go to the dealership and pay the diagnostic fee....
Old 11-14-2017, 03:12 PM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
