Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Boxster & Cayman Forum
Boxster engine weight
I have a 2.7 coming to put in my boxster project. Anybody got an idea how much it weighs? It's a 2002, include the alternator, air oil separator, and a starter, but no a/c compressor or throttle body.
I need to know if a light weight trans jack will work
Brian Lamberts
Tucson AZ
Old 10-26-2017, 04:45 PM
one of the great unwashed
patkeefe's Avatar
Probably around 300# or so (a guess...I have no details). What is a lightweight transmission jack? I use a motorcycle jack on my 911 for the engine and the trans together. From my recollection of transmission jacks, one of those should work.
Patrick E. Keefe
78 SC
01 Boxster
Old 10-26-2017, 07:16 PM
Thanks Pat. Yeah, I decided to use my motorcycle jack. If one is just swapping engines, do you need to remove the transmission (tiptronic) too?
Brian Lamberts
Tucson AZ
Old 10-27-2017, 06:32 AM
JFP in PA's Avatar
With a Tip, it is easier to drop it as an assembly and then split it; with a manual you can go either way.
And the engine alone weighs around 450 Lbs.
Accrochez-vous bien de vos rÍves..........."
Old 10-27-2017, 06:49 AM
Thanks. I'll investigate that. Would give me the opportunity to replace the CV boots. Getting to sound like a bit of a long haul project.
Every new car/engine/trans project is quite a learning experience.
Brian Lamberts
Tucson AZ
Old 10-27-2017, 03:51 PM
