Magnetic sump plug ?
My mechanic tells me that he doesn't like to use a magnetic plug, reason being that any metal should be trapped in the filter, rather than being able to come off the plug and circulate ??
Foolproof underestimates the dedication of fools
Old 11-29-2017, 12:02 PM
JFP in PA's Avatar
What he is missing is that some ferrous metallic grit is so fine it passes through the filter. The filter also has an infamously poor by pass valve that tends to stick open, letting all debris by pass the filter.
Get a magnetic plug, and if you really care about the car, get a spin on filter adaptor. Your engine will thank you.............
Accrochez-vous bien de vos rÍves..........."
Old 11-29-2017, 01:00 PM
Any loose material that is trapped by the magnet on your plug is no longer circulating through your engine. Think of it as a pair of suspenders to go with your belt.
Your mechanic probably doesn't like several things you do...so what?
Old 11-29-2017, 01:07 PM
Consider those particles have to go through the pump to reach the filter.
Old 12-13-2017, 10:11 PM
Emo993's Avatar
+1 JFP, and even a magnet to go on the metal filter. Best, Mark
1974, 914-6 GT Tribute
2007 Cayman S
1998 993 Carrera S, speed yellow (Yellow Bird) gone but not forgotten.
2017 Golf Sportwagon 4motion
Old 12-15-2017, 04:33 AM
If you retain the factory filter setup, it's recommended that you change the filter housing every several years as the bypass spring looses tension. The other option is to put a spin on filter adapter and full flow filter that prevents debris from entering the engine. Pelican offers these with the magnetic drain plug as well.
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
Old 02-24-2018, 05:30 AM
thank you cnavarro for website it is interesting.
Old 02-25-2018, 04:11 AM
Magnetic plugs are very inexpensive. Not sure how much good they do, but they certainly don't hurt anything. A eurocar shop friend says that OEM filters are good, doesn't recommend the spin on's. I have the spin on filter kit, it seems pretty good and I'm using a high quality Fram XG filter.
One way or another, it kinda seems like snake oil to me.
Brian Lamberts
Tucson AZ
Old 03-04-2018, 07:34 AM
+1!
It's my motor, and my car.
Brian Lamberts
Tucson AZ
Old 03-04-2018, 07:41 AM
Nothing wrong with OEM filters. We use them with the stock filter housings on the .2 cars with the MA1 engine.
The M96 (and M97) engine generates more debris, ferrous and non-ferrous, than most any other Porsche engine I have seen. The spin on filter adapter delete the bypass as already mentioned, preventing debris from re-entering the engine when the filter bypasses.
We have inspected dozens of different brand filters and the only spin on filters we recommend sticking to Wix or Napa Gold/Platinum filters. Their construction is superior. I did not find a single Fram filter I would use or recommend.
Charles Navarro
Old 03-05-2018, 08:25 PM
Why I chose Fram XG filters. Untitled Document
And a magnetic drain plug.
Brian Lamberts
Tucson AZ
Old 03-06-2018, 06:17 AM
I cut apart all the 1042 Frams along with all the other brands available at your FLAPS and Amazon. Wix and Napa Gold/Platinum are still the best.
Charles Navarro
Old 03-06-2018, 07:04 AM
