Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Boxster & Cayman Forum
Aluminum Spark Plug Tubes
Looking for oil leaks I found five out of six spark plug tubes leaked into the plug area. The sixth was changed about a year ago and dry. The leaking five were easy to remove because the o-rings lost enough compression that the tubes could be rotated. The recently replaced one was difficult because of the smooth bore and taper left little grip even with a blind hole bearing puller. Instead of just replacing the o-rings I decided to make new tubes in aluminum with a groove at the end so a puller has some grip.
The manual says to push the tubes into place. I found they could not be pushed in by hand but I was able to press them in using the coil and mounting screws.
A little heavier than the plastic but they will not break when removing them.
Old 12-13-2017, 09:17 PM
Grand-Cayman's Avatar
Wow - that's awesome!
2016 Cayman GT4
2015 JCW Mini Coupe
2015 Fiat Abarth
Old 12-15-2017, 04:35 AM
Porsche's Love-em Live-em
Very interesting!
Old 01-12-2018, 10:15 AM
still plays with cars...
Nice!
Taking orders?
Old 01-12-2018, 05:03 PM
Very nice. Probably spendy to produce. But very nice.
Brian Lamberts
Tucson AZ
Old 01-14-2018, 05:15 AM
Price would depend upon how many sets to make. The setup time has to be added in. What interest is there?
Old 01-16-2018, 09:25 PM
I'm interested, But it depends on the price. I just replaced my plastic tubes and o-rings, so I could wait for you to produce some or if the price is good, could pay in advance.
Brian Lamberts
Tucson AZ
Old 01-18-2018, 01:14 PM
Obviously has to be worth your time too.
As Brian said, Ballpark WAG?
PM if you donít want to outright post a price.
Thanks..
Old 01-18-2018, 05:51 PM
I looked into it, I have a friend with a CNC mill. Decided not to, couldn't find a reasonably priced source for the o-rings.
Brian Lamberts
Tucson AZ
Old 01-30-2018, 05:54 AM
Sorry for the delay, Windoz decided to take a dump and, of course, when it goes so do all your programs.
I have enough material for 4 sets (24 tubes). They would be $23.49 each including the silicone O-rings.
Old 01-30-2018, 01:36 PM
Not a bad price, I sent my friend a new tube to prototype. Depends on the price from my friend. But the $150 for the set is affordable, especially if you can provide o-rings (and maybe replacement ones.)
I wonder if it would be effective to mount them in with the o-rings and high temp RTV?
Brian Lamberts
Tucson AZ
Old 02-02-2018, 07:01 AM
Originally Posted by afterburn 549 View Post
Dont use RTV with "O" rings please .
Its bad ju ju.
Use silicone grease so it will always feel comfortable and move to fit.
next
Would a 3d printer do the job of making them?
Bad JuJu?
I'm old and out of the loop on 3D printers. However a CNC mill could kick 'em out pretty fast. My buddy was a local supplier for Boeing aircraft up in Renton WA.
Brian Lamberts
Tucson AZ
Old 02-03-2018, 02:45 PM
