Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Boxster & Cayman Forum
rumble noise from rear on hard turn
Turning left at almost full lock makes a rumbling noise from the left rear. It does not happen with a hard right turn. A little less than full lock the noise does not happen. Just had new rear tyres put on but I do not see how that could affect it.
Any ideas?
Old 12-28-2017, 04:39 PM
Check your wheel lugs for correct torque. If they’re tight, then investigate wheel bearings.
Old 12-29-2017, 03:42 AM
Check for rubbing on the inside fender wells, and the outside fender lips. Not all tires are created equal, and your new ones could be wider than the old ones.
'87 Carrera (3.4L)
'07 Boxter
Old 12-30-2017, 05:30 AM
Are the boots on your CV joints intact?
Brian Lamberts
Tucson AZ
Old 12-30-2017, 06:05 AM
Mine was doing the same thing. I replaced the motor mount and it fixed it. Good videos on how to do it. I would highly suggest buying the bushing already pressed in the mount on pelican parts for like 160ish. Worth it.
Old 01-30-2018, 03:21 PM
I had mine pressed in . Saved almost $100.
Brian Lamberts
Tucson AZ
Old 02-02-2018, 06:55 AM
