porscheag_101's Avatar
2007 Porsche Boxster S 3.4L front radiator Fans failures
Hello mates
I have rebuild a 2007 Porsche Boxster S engine
Changed thermostat , Coolant temperature sensor and the fans module on the passenger side and the fans still not working
Any help please ????
Sent from my SM-N920C using Tapatalk
Old 12-31-2017, 03:53 AM
NOTE
Tge fans starts via Piwis if i give them an order even the engine compartment fan is stopped.
Thanks in advance
Old 12-31-2017, 03:54 AM
Turn on A/C which should activate both fans, if no luck there is a problematic resister mounted close to the fans on 986 model, may be same issue on yours. Search internet for replacement info.
Old 01-06-2018, 12:25 PM
Hello Dear
The problem now that i dont have coolant circle in the car
The water hoses under the car driver side very hot and right side so cold?
Old 01-06-2018, 08:36 PM
