-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Engine compartment soundproofing (http://forums.pelicanparts.com/boxster-cayman-forum/983349-engine-compartment-soundproofing.html)
tjonesmn 01-07-2018 06:09 PM
986 boxster
Can anyone recommend an engine compartment soundproofing other than oem?
also any tricks you are willing to share in removing the existing product would be appreciated.
I have the engine out and the existing product is falling off.
thank you.
mikefocke 01-08-2018 08:37 AM
Only thing I can think of is going to a boat shop that services big yachts as they use sound deadening material in the engine/generator rooms with diesels.
Dmitry at Pelican Parts 01-08-2018 01:47 PM
You can try something like Dynamat for a sound deadner; not sure if you can entirely soundproof the compartment. Depending on the thickness of the material, you may be able to eliminate most of the noise though. Hope this helps a bit and best of luck!
JackDidley 01-08-2018 06:29 PM
Do a search on this.
https://www.lowes.com/pd/Peel-Seal-Instant-Waterproof-Repairs-6-in-x-25-ft-Aluminum-Roll-Flashing/1018733
I put it on my Cayman engine cover today. No test drive yet.
turboflyer 02-07-2018 06:59 AM
I think i would see at what temp it starts get to soft or melt before I went down the road. Gets pretty hot in that bay.
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
